Is this how it should work?
When I Fade All either using an SFR cue or by using Shift+Esc it seems to fade almost straight away. I use this at the end and the one remaining cue has a 5 second fade out. Even tried putting 5 second overide in the SFR cue and it still seems to fade out - it might be using the default time whioch is 2 seconds.
A fade of the specific cue works fine and fades out in the 5 seconds.
I can see reason for Fade All using the default - Ie if you had something like a 20 minute fade. But just wondering if that's the way it's meant to work or not.
Ohh and I can see a workaround - using and SFR cue - Fade out all earlier cues. Seems to work.
[Resolved] Fade all not respecting fade times
Re: Fade all not respecting fade times
Phil, in Options / General, what do you have as the 'Fade All' Time? The default setting is 1 second.
That'll be it - I've never changed that.
Thanks Mike.
Thanks Mike.
