I'm trying to use the Mute Chanels feature release in 11.8.5 I think it was against a Beheringer X Air 18 chanel mixer. Is thgis supported as it doesn't seem to work.
If it's not do you know what the value of "value" should be for mute or unmute in the CC command?
Where is the diagnostics file located if you need it? I've attached the SCS file anyway.
Phil.
(Resolved) Mute Chanels
Re: Mute Chanels
Cancel that - the mixer had dropped off my WiFi so I wasn't seeing it on the PC .
All works - except I can't seem to get the scribble strip feature to work but that's a minor problem and not necessarily something I want to do.
Phil.
Phil.
