[Resolved] - Turning on a fixture will stop fading in/out others
Ribot
Post by Ribot » Mon Nov 08, 2021 4:16 am
Using lighting cue, I faded in a couple of fixtures. At a specific time, when the fading procedure is still running, I start another lighting cue to switch on a fixture which is not involved in the fading ones. This switch causes an immediate stop of the fading process.
Regardless if it's done as a manual cue, an auto cue released by ' n sec before end' or as a 'cue marker induced' start.
I used the option 'do not fade out others'.
It occurs during 'fade in' as well as in 'fade out'
I'm actually using version SCS 11.8.4.1ah
Mike could fix the problem and provide me with a new version of SCS.
Thank you so much Mike
