[Fix 11.9.0] DMX Capture problems
Posted: Thu Sep 30, 2021 4:26 am
by Vis Comica
Hi, new here,
i am running scs 11.8.5 pro plus on win10 with the enttec USB PRO MK2 and drivers installed from scs. My testsetup is a RGBW Led Par and a stupid 6 Channel DMX Console. I can create Lighting cues manually with the fixture sliders, that works perfect.
I send DMX on DMX2 and i receive DMX on DMX1.
In the Prodprops/devices/cuecontrols Test DMX Control my console speaks perfectly to scs (except there is 91% on ch 7 ??).
If I create a lighting cue with DMX In , capture DMX Snapshot, nothing happens, dmx Items / Values stay empty.
If i create a cue with start DMX Sequence, i see the orange dot blinking and when i stop i see the list of "states". In playback, that sequence stays on his first step and doesn't go further. The timer bar is running though.
If i try to make another capture sequence, orange dot is not blinking and DMX Items/Values stay empty. Test DMX Control in devices still shows receiving DMX from my console.
And also, the data from my console is not throughput to the Led Par, which i assume it should do when in DMX In mode.
Re: DMX Capture problems
Posted: Thu Sep 30, 2021 4:25 pm
I've emailed you details of a new version to try. Hopefully that will fix the DMX Capture issues.
