x32 Port Not settable
Posted: Thu Mar 12, 2020 12:16 am
SCS 11.8.2.2
In Production Properties - Devices - Control Send
when selecting a Network Out device with Remote Device set to Behringer X32 Digital Mixer the IP address can be set but the Port No. is grayed out.
The workaround is to change the device to Behringer X32 Compact Mixer which sets the port to 10023, then going back and changing the device to Behringer X32 Digital Mixer.
NOTE also that this changes the Name Used in Cues so then that value has to be reset. Note that the Name Used in Cues should not change...the Cues are the cues...if I want to change the Name Used in Cues I should be able to do that, but having the system auto change that seems inconsistent.
