[Fix 11.6.2] MIDI Control issue?
Posted: Mon Jun 12, 2017 8:10 pm
Hi Mike
There is still a problem with MIDI control.
I have various cues with Midi ControlChange commands. This works perfectly.
However, as soon as I add a cue with MIDI file somewhere, in order to create an automatic fade, the ControlChange cues are no longer sent to the mixing console. SCS supposedly runs them out, but they do not arrive at the console. Only the cue with the MIDI file comes on the mixer.
Even if I use the ControlChange command over MIDI-1 and the MIDI file via the dummyPort output, I have the same result.
Once a cue with MIDI file is inserted, all other MIDI commands are blocked, no matter what port.
The MIDI file I have previously recorded with MIDIEditor.
MIDI reception continues.
