Hi
I working on window 10 pro 64bit and use TVideo Grabber for video library
Since I made the last update, I have a problem with the video sequences in my session. When I switch from one video to another in the cutter before the end and I stop the last one by a Fadeout, a still image of the first video remains in place before cutting suddenly.
When I do the same schema in a new session I do not have problem. I do not understand and it is a fairly consistent show to redo. If you can avoid repeating my show completely would be really good.
Sorry for my approximate English
I am French and i don't speak English very well.
thank you very much
Jonathan
[Fix 11.5.2.4] Problem with video since update version
Re: [Fix 11.5.2.4] Problem with video since update version
Jonathan,
