[Fix 11.4.2]Audio cue current pos stops displaying in editor
Posted: Wed Dec 02, 2015 9:55 pm
When editing a cue file, initially the current position marker in the audio graph and the green Completed slider behave themselves normally i.e. when you press the Test button both the slider and current position marker advance with the playing cue. However, after performing editing on the cue file for some minutes I find that when testing any audio cue, the current position marker and Completed slider just stop moving even though the file itself is playing.
As you can appreciate this issue is a nuisance when one is trying to use the current position marker or completed slider to determine whereabouts in the audio cue file you are when trying to set fade/fade out points, relative start end/points etc. The only workaround that I have found is to close and re-open SCS. I have been unable to determine whether I am performing a particular sequence of operations to lead to this problem but it just seems to happen after a while whenever I am doing any editing.
I am currently running SCS 11.4.1.1 on Windows 8.1 although I have observed this same issue in previous versions of SCS and on several different PCs/Windows versions.
For me this has been such an ongoing and obvious issue with SCS that I am surprised no one else appears to have reported it - at least I can find no similar problem report on this forum. Perhaps it does only happen to me.
I hope you can help.
