SCS version 11.4.0.4j.
I have been having a problem with the x-pos of images changing when displayed.
The set of our current show has the screen (the cyclorama) half covered by a movable wall in some situations. I got around this issue by moving the image off to one side using the x-pos slider in the cue properties. The problem is that sometimes the image takes on the x-pos of the previous image cue instead..... a hit of the STOP ALL key and and run the cue again and it displays correctly.
I have captured the debug file and will email this shortly to you with two photos I took of it happening during the checks before the show. The first image shows the image is only half the screen, which is incorrect. I hit ESC and then GO and it displayed correctly (the second image).
The cues that I managed to reproduce last night was Q65 Q66 Q69 Q71.
Best regards,
Mark Perry
