Im trying to play back multi-part tracks, something i have done may times before. The audio files for each que are all arranged as sub ques and are 'linked' .
When the que is activated, the first second or so of all the files is played, but then it jumps back to the begining of the file(s) and starts playing again from zero.
So for example on the 'click track channel' we get '1 2, 1 2 3 4, click click click....' as opased to '1 2 3 4, click click click....'
Now im no stranger to resolving audio glitches with SCS, but this one has me stumped:-
If i play the files indervidually from the editor, they all play ok with the exeption of the file at subque possition 1 - which glitches as mentioned above.
If i move the 'click' file to subque position 2 and play it, it plays just fine, but the 'guitar' file, which has just enherited possition one, now glitches.
It does not matter which file i put in subque possition 1, it always glitches, and it does not matter which que im in. Its always sub que position one.
Now, as sub que 1 is glitching when the entire que is triggered, every single audio file also glitched because they are all linked - at least the re-sync is working
The glitch only ever happens at the begining of the ques, and once it has glitched the the rest of the que plays out as it should.
Iv tried everything i can think of, including changing from asio to direct sound (and back), reinstalling drivers, running a diffrent machine (hardware identical) and running the que file on an older vertion of SCS (11.2.3)
Iv even tryed re encodeing the .wav files, but all that and more has made no diffrence at all
Any ideas?
(dump file attached, with extention changed to .txt so i could up load it.)
