[Fix 11.3.2] SFR warning
Posted: Sat Aug 02, 2014 12:38 am
V 11.2.4 and 11.3.1
Scenario:
Cue 1 scene change music
cue 2 SFR to fade cue 1.
If cue 1 runs out before cue 2 is activated then (correctly) the yellow warning appears that says "Warning next manual cue has nothing to do....Press go to complete etc". However if you press Go immediately (ie within a second) after the yellow warning appears, the cue stack moves on to the next cue but the warning doesn't disappear as it should. Pressing Go again removes the warning but then also plays the next cue!!
It seems to need a few seconds to elapse before you can press Go to clear the warning AND move to next manual cue. Although this isn't generally a normal situation in that cue 1 has run out before the fade cue it can happen, for example, during scene changes where the timing is not precise (or it did with us....)
Nick
Scenario:
Nick
