[Resolved] SCS 12.5 immediately crashes
Posted: Tue Jan 14, 2014 7:43 am
by Nipper
I have just installed SCS on a windows 7 machine that has had all updates applied. On first run this error appeared with the demo file and going straight to the editor. I have used SCS for a long time with success on other machines. I have attached a dump file and screen print of the error.
John
Re: SCS 12.5 immediately crashes
Posted: Tue Jan 14, 2014 8:24 am
First of all, it looks as if SCS hasn't been installed properly, because the dump file shows that xVideo was not initialised. Try uninstalling SCS 11 and then re-install SCS 11 by running scs11.2.5_win32setup.exe.
If that doesn't help, try the Special Start option. Select 'factory reset' and then click OK.
Posted: Wed Jan 15, 2014 7:38 pm
by Nipper
I have tried your suggestions and the same thing happens.
John
Posted: Wed Jan 15, 2014 10:49 pm
John,
I've emailed you details of a tracing version to run.
Posted: Thu Jan 16, 2014 8:58 am
The log file shows that you have no DirectSound audio interface and SCS is obviously not handling that condition. What audio interface do you have? Is it a device that supports only ASIO?
Posted: Fri Jan 24, 2014 9:09 am
by Nipper
following your last post I investigated further and found activeX hadn't been installed. Have installed it now and it is working fine.
Thanks for your help,
