Enable/Disable Cue Limit?
lwalton
Post by lwalton » Thu Apr 20, 2017 3:11 pm
Hi Mike, always enjoy using SCS and trying new things.
Using SCS 11.5.2.4 (x64) Pro Plus
My current issue is the need to enable and disable a number of cues spread thru the cue list.
My first Enable/Disable Cue with its 5 ranges to disable the cues works and saves ok.
But my subsequent Enable/Disable Cues to either disable more cues or re-enable the cues, although they initially work, they show empty entries in the sub-cue section after saving and reopening the cue file.
I've created a quick test file with 5 Note cues.
My 1st Enable/Disable Cue disabled the 1st Note Cue only.
My 2nd Enable/Disable Cue was set to re-enable the 1st Note Cue only.
After saving the cue file and reopening it the enabling entry in the 2nd Enable/Disable Cue had moved from the first slot in the sub-cue list to the second slot.
Subsequent additions to the 1st Enable/Disable Cue slots pushed the entry in the 2nd Enable/Disable Cue down a slot when the file was reopened.
When all 5 slots were used in the 1st Enable/Disable Cue, no entries remained in the 2nd Cue.
Is this due to a limit to the number of Enable/Disable Cue actions or a bug?
Cheers,
Lindsay
Lindsay Walton
Re: Enable/Disable Cue Limit?
Post by Mike Daniell » Fri Apr 21, 2017 10:06 am
Seems like a bug. To save me some time in trying to build a cue file to reproduce this, could you email me your cue file (the .scs11 file)?
