Toggle activation faulty
Soundbloke
Post by Soundbloke » Sat Nov 21, 2015 4:52 am
Today I wanted to fire an audio cue using "toggle" - hot key first to fire, then again to stop it (with a 4 second fade out)
it works the first time I hit it, but on subsequent goes, it just restarts the track instead of ending it.
Re: Toggle activation faulty
Post by Mike Daniell » Sat Nov 21, 2015 11:55 am
Just tested it here and it worked OK. Seems like your hotkey is not 'toggle' but 'trigger' (the default setting). Is it definitely 'toggle'?
Soundbloke
Post by Soundbloke » Sun Nov 22, 2015 9:09 am
Thanks for your reply Mike,
It was definitely a "toggle", But I did have a "Fade all other playing cues" subcue nestled within it which may have confused it a bit!
I also had a hotkey on my numeric keypad for a 'slow fade out and stop' anyway so was not a problem.
