[Fix 11.3.2]Cannot edit audio cue after test playback 11.3.0
TBTG
Post by TBTG » Sun Jul 20, 2014 1:28 pm
When first in editor mode the ability to adjust devices and level sliders are available.
Before playback and slider edit
Screen Shot 2014-07-20 at 1.14.04 pm.jpg (243.37 KiB) Viewed 545 times
After moving "Start At" and "End At" sliders and playing the test audio, all the audio cues loose the ability to be updated.
After playback and slider edit
Screen Shot 2014-07-20 at 1.15.26 pm.jpg (252.36 KiB) Viewed 545 times
I had this problem in SCS 11.3.0, updated to SCS 3.11.1 - no difference. Cannot find any references in help / documentation.
Dump emailed.
Version
Screen Shot 2014-07-20 at 1.19.23 pm.jpg (59.32 KiB) Viewed 545 times
Martin
Re: Cannot edit audio cue after test playback SCS 11.3.0 11.
Post by Martin » Sun Jul 20, 2014 8:52 pm
I've had this problem too.
If you look just above the list of audio devices (Rear, Main, etc), there is a drop-down field which now says ‘Level Point: End’. If you open the drop-down list and select ‘Audio Devices’, all will be well, at least until the next time.
There is probably an option somewhere which will prevent this from happening but I haven’t found it yet.
TBTG
Post by TBTG » Mon Jul 21, 2014 10:27 am
Thank you Martin
That certainly saves swapping window to test every sound selection :)
Post by Mike Daniell » Fri Jul 25, 2014 10:19 am
Fix ready for 11.3.2.
This was a design flaw rather than a bug per se. Whenever you clicked on a marker in the audio graph, SCS 11.3.0/1 would 'select' that level point or start/end point, and display the relative levels etc for that selection. For 11.3.2 I've now changed this so that if the current selection is 'Audio Devices' then the selection is only changed if you use Ctrl/Click to change the level or pan setting, not if you just use Click to change the position of the point.
