Hi Mike ,
I have two computers SCS11.2.6 installed with Windows 8.1 64-bit operating system , a desktop and a laptop Toshiba Hp . Use the two alternately by two audio interface An M -Audio Fast track pro and a Behringer Firepower 610, both connected by USB . So far I have been using the ASIO drivers (ASIO using bass in the program) to the interfaces own cards .
In both functioned perfectly and outputs all the elements at all times.
A couple of days ago I wanted to try on the HP computer the 11.3 RC4 version and installed above the previous . From there , they have disappeared from the production editor ASIO drivers card alone gives me an option ASIO drivers or ASIO multimedia directx full duplex.
Working with the sequencer Cubase 7.5 , and it works perfectly if the ASIO drivers of the interfaces. It is as if not specifically acknowledge Show Cue drivers of interfaces. Through the Behringer ASIO multimedia interface works, but with high latency.
I uninstalled version 11.3 $ RC , and re- installed 11.2.6 but now does not recognize the interfaces ...
I do not know really what to do , because in the Toshiba laptop all goes well ( did not want to install version 11.3 on it) , but now I can not prepare projects at home with the HP computer ...
Would appreciate the help you could give me .
Thanks in advance, and sorry for my "googlenglish"
Alex .
PS Now I e-mail you the report of SCS 11.2.6
[Resolved] Missing ASIO Cards drivers in SCS 11.2.6 AND 11.3
Re: Missinga ASIO Cards drivers in SCS 11.2.6 AND 11.3 rc4
I can't see that SCS could affect what interfaces are available. I've emailed you for more info and with details of a tracing version so I can check what ASIO interfaces the BASS audio library is detecting.
Re: [Resolved] Missing ASIO Cards drivers in SCS 11.2.6 AND
Alex has advised that this issue has been resolved/fixed. The explanation was quite complicated, but if anyone has encountered a similar issue then let me know and I can forward Alex's comments.
