[Fix 11.10.3] "invalid memory access" error when creating a new lighting cue in editor after preparing fixtures
Hi Im Max,
My Scs crashes every time i try to create a lighting cue, after i prepared all fixtures and lighting devices it says error: "invalid memory access" when it tries to load my fixtures so im not able to create lighting cues :/ can you helb me?
i used scs 11.9.8(x64) first,
then updated to scs 11.10.2(x64) but it didnt change or solved the problem .
thank you for your help
max
max
- scs11_log_20240705_234537.zip
- log file with the same error but a newer scs version and try to wqork with artnet instead of the direct enttec open dmx
- (77.33 KiB) Downloaded 275 times
- scs11_log_20240705_230046.zip
- log file with old scs version
- (44.37 KiB) Downloaded 282 times
- error message screenshot
- scs fehler.png (96.6 KiB) Viewed 9520 times
Re: "invalid memory access" error when creating a new lighting cue in editor after preparing fixtures
We will take a look and get back to you.
Hi just to note that both the log files were using version 11.10.2, is that what you wanted to post?
I've done quick test here and it works OK. Please email the log file scs11_log_20240705_202622.log to support@showcuesystems.com.
it doesnt metter what version i use. the old logfile is already overwritten and i missed to store it... so i updated to the newer version, you can see in the log file. but it doesnt seem to be the problem of the scs version as im getting the same error with the new version.
i can reproduce the error today with the new scs version and send you the sceenshot and the logfile of the same error again
so here is a screenshot and a logfile of the same error happening just right now. both belong together this time .
thank you for help
thank you for help
- scs error today.png (91.52 KiB) Viewed 9478 times
- scs11_log_20240707_082933.zip
- (61.36 KiB) Downloaded 299 times
Hi Max, we have apossible solution for you to test, can you please send an email to support@showcuesystems.com and I will provide you with a link to a beta version for you to try.
Awesome ! The Version you´ve send me works. No Memory error anymore .
Thank you for that awesome support.
cheers Max
cheers Max
