I am using SCS 11.8.2.1 (64)
I am trying to use a Blackmagic Web Presenter as a web cam input to SCS. I can get the device loaded as a video capture device and it seems to get a signal in test mode. However it only displays the top left corner of the video input. I can get the signal to the 2nd screen if no other cues are in my current show file. Once I try to create a cue that calls that camera it will display on the 2nd screen for about 3 seconds then freeze the app and the the app closes. I have tried several different options in the LAV Video Configuration, changing the Video Playback Library to all the options available and it hangs every time I call the cue in the show. If I switch the Video Capture options to be the built in or a MS USB web camera it seems to work without trouble.
I have updated all the drivers for all the pieces involved with no luck.
Any ideas on how to fix the video size and the shutdown issues?
Blackmagic Web Cam issues while running cues.
