[Fix 11.8.1] Pre-viewing sub-cue in editor triggers the cue in the main window
d_korman
Post by d_korman » Fri Mar 15, 2019 12:27 am
Recently, pre-viewing an audio-file sub-cue in the editor window causes the main cue to run in the main window, starting at that sub-cue. This is quite a complex show and the cue ( Q61 out of nearly 200) in question has 19 sub-cues. The smallest log-file is 650K zipped which is too big to attach, and I'm afraid I simply do not have the time to try to create a minimal set of cue that show the problem. I could put the file on a web-server and provide a link though.
Dave
Re: Pre-viewing sub-cue in editor triggers the cue in the main window
Post by Mike Daniell » Fri Mar 15, 2019 8:21 am
Dave, just email me a diagnostic file and tell me which cue and sub-cue caused this problem when you previewed it in the editor. You can create the diagnostic file by selecting 'Create Diagnostic File' from the drop-down menu displayed when you click the Help button in the main window. The file will be saved in a folder named "SCS Diagnostics" under "Documents". No need to reproduce the problem for this - you can just start SCS, open the cue file, and create the diagnostic file.
d_korman
Post by d_korman » Sat Mar 16, 2019 1:10 am
Email sent.
