I start each cue sequence with a manual note cue
This is followed by auto action cue maybe an audio file, send or fade cue
For ease of editing and operating I make a space using a set position cue of a none used audio file
With the the text and background colour set set to the same as the main window it just becomes a space
This makes each manual cue stand out and easy to drop into when rehearsing
This works well but has a few drawbacks but the main one is it takes up space in the cue panel
What I would like please is a space cue that doesn't need a name or have a cue number and is displayed in the main window but not the cue panel
David
space/none cue
Re: space/none cue
You can prevent the cue from being displayed in the cue panel by setting Display/Hide Cue to 'Hide Cue Panel' in Cue Properties.davidcoliver wrote:This works well but has a few drawbacks but the main one is it takes up space in the cue panel
