SCS and Chamsys QuickQ
Posted: Wed May 29, 2024 2:42 am
by Vilgaard
Hi there!
I just started using SCS in our little community theatre. For lighting we use a QuickQ 30 from Chamsys. I already figured out how to send MTC to the desk, this works. With an SFR cue I can stop the MTC.
Problem with QuickQ is that it stays on the last timecode it received.
Is there another way to start a lighting cue in QuickQ with SCS? Timecode is great for songs where I like to program lights very specific timing but sometimes (most of the times) I just want to start a single light setting without sending MTC.
regards,
Jeroen
Re: SCS and Chamsys QuickQ
Posted: Wed May 29, 2024 8:11 pm
by dee99
I have not used QuickQ I normally use the full Chamsys PC but I can trigger cues on that with OSC commands via the network using a control send cue in SCS. Alternatively can you set QuickQ to trigger different cues at different times, if so you can do this with multiple MTC cues.
e.g. QuickQ Cue 1 runs from 1:00:00 to 1:00:30
QuickQ Cue 2 runs from 1:10:00 to 1:10:25
etc
I would allow for a bit of preroll on the MTC cues to allow QuickQ to sync up. Note you won't be able to run more than 1 cue at a time with this method.
Does QuickQ allow MIDI note triggering?
Posted: Thu May 30, 2024 9:17 am
by Vilgaard
Hello Dee,
Thank you for taking time to answer my question.
Never used OSC on my QuickQ but it appears to be possible. If not, I will use your other suggestion using the MTC. I don't think it's possible to use midi notes.
regards,
Jeroen
