Level changes on hot keys
Posted: Tue Jun 01, 2010 7:05 am
by Paul Barnett
Hi Guys , just invested ( and it's a worthwhile investment ) in SCS and have a question on hot keys.
I have created a hot key which runs an emergency services siren , I then have 3 level change follow
on cues which pan left and then right and then return to the centre.
My question is after the cue has run once the follow ons read as completed but I need to run the
hot key again , how do I auto reset the follow ons ????
Sorry if this is basic but I've had browse and can't find the answer.
Cheers
Paul
Re: Newby question on hot keys
Posted: Tue Jun 01, 2010 7:21 am
Paul,
Could you email me your cue file (the .scs file)?
Posted: Wed Jun 02, 2010 8:00 am
by Paul Barnett
I've emailed as requested , let me know if you need any more.
Thanks for the quick response so far.
Cheers
Paul
Posted: Wed Jun 02, 2010 5:48 pm
Thanks for the cue file, Paul. You can include your level changes with your hotkey cue by making the level change cues subcues of the hotkey cue.
Here is an SCS 'print' of the cues in your test file as you currently have them:
Before
In the Editor, starting with Q4, click
to make Q4 a subcue of Q3, then do the same to make Q3 a subcue of Q2, and then do the same to make Q2 a subcue of Q1. Change the Relative Start Times of the subcues to delay the level changes as required. The result will look like this:
After
Now when you press
S your siren will play and the level changes will take place as required, and because the level changes are included in the hotkey cue, they will occur every time you use the hotkey.
Posted: Wed Jun 02, 2010 10:59 pm
by Paul Barnett
Thanks Mike, much appreciated , I knew it would be something simple
Posted: Sat Jun 05, 2010 10:18 am
by Dngnkeeper
This might be good in tips and tricks.
Re: Level changes on hot keys
Posted: Sat Jun 05, 2010 12:10 pm
Topic moved and, as you can see, I changed the subject for the benefit of users perusing the Tips & Tricks Forum.
