Creative Sound Blaster USB
[newbie!] What a great product - Thanks !! just starting to get to grips with it. Tried plugging in a Creative Labs USB Sound Blaster unit but was unable to successfully "address" each of the 6 channels available on the 5.1 outputs the unit provides. Am I doing something wrong .. or using the wrong piece of hardware?
Sound Blaster Live 24 bit USB
I ran some tests and came up with the following results :
Signal output was present at the "Front" speaker jack of the SB USB when FRONT or PAIR1 selected in SCS
I could get no signal at all out of the SB USB "Rear" or "C/Sub" jacks - no matter what speakers I chose in SCS (except a very low output from the CENTRE speaker when FRONT speakers selected in SCS.)
Hope this helps ...
Hope this helps ...
That's good.Signal output was present at the "Front" speaker jack of the SB USB when FRONT or PAIR1 selected in SCS
That's what some others have reported. I've had people run test programs and the test programs work OK, but I regret I cannot identify why the test programs handle the speakers correctly but SCS doesn't, and apparently only with Creative Labs devices, afaik. For example, the onboard C-Media 7.1 chip on my PC handles speaker separation perfectly, as do my M-Audio, Echo Gina and Edirol devices.I could get no signal at all out of the SB USB "Rear" or "C/Sub" jacks - no matter what speakers I chose in SCS (except a very low output from the CENTRE speaker when FRONT speakers selected in SCS.)
It's been a long time coming, but a new option has been added in 9.2.6 that I hope will fix this problem.
If you find you are getting issues like those explained in this topic, which I believe only occur with Creative Labs cards, then click on View / Options and select the Audio Driver tab. In 9.2.6 there is a new checkbox, labelled "Do NOT use floating point for audio channels". Tick that checkbox and then click the OK button. You may then need to restart SCS as this change will not affect currently open audio files. After restarting SCS your speaker assignments should now be working.
