mute automation
Posted: Sat Jul 30, 2005 3:11 am
hello, im helping my friend set up his A&H GL4000 and GL4 consoles with mute automation. I was searching for software to send midi cues to the mixers, when I stumbled upon your site, which is interesting because he uses the standard version of your software in his rig.
I would like to know if the midi functions in the proffesional version support sending the following data:
for mute on: 91 CC 3FH where CC is the channel on the console
for mute on: 91 CC 7FH where CC is the channel on the console
I believe that those commands are synonomus for a standard command, I just dont know which.
can your pro software do this, and will it be easy, or will I have to type 91 CC 3FH into all of the cues? If not, do you have any other recomendations?
thank you.
thank you.
