Mapping issue???
Posted: Wed Sep 27, 2006 8:19 am
I've emailed you directly, but I'm posting this here in case anyone else has encountered this error and knows how to work around it...
Here's the series of events as it stands...
I programmed the sound plot from my home PC, then copied all the files to my thumb drive. I brought the thumb drive to the theater and downloaded all the files to the production PC. The Production PC crashed every time it opened the .scs file from the local hard drive. The only way I could get it to work on the production PC was to run the files from the thumb drive. I had this problem using both 9.1.5a and 9.2.6.
This morning, I tried to replicate the problem with my laptop but it worked without a hitch. I also tried it on my home PC and it worked fine. But when I tried again on the production PC, it crashed again.
Then I realized that I had multiple versions of SCS running on the production PC so I decided to clean house, uninstall all versions, then reinstall 9.1.5a. That's when I discovered that I only had the minimum install set and couldn't install completely. When I went to the members area of your website, I was unable to find the download for 9.1.5a anymore, but only 9.2.6. When I tried installing 9.2.6, and opened the file on the production PC, it doesn't give me an error. It just tries to open, then immediately crashes without reporting any errors.
I have 2 rehearsals left before we open (tonight and tomorrow.) Currently, even with the reinstall, this file will only run off my thumb drive which scares me.
I hope you read this soon.
Thanks for any help you can offer.
PS - after installing 9.2.6, I was able to reinstall 9.1.5a and still no joy.
