SCS 11.10.7 Available
Locked
Post by Mike Daniell » Mon Mar 03, 2025 3:50 pm
SCS 11.10.7 is now available on the Download page of the Member Area. This is primarily a bug-fix release, especially for SCS 11.10.6 users.
New and Changed Features in SCS 11.10.7
  • In Production Properties / General added fields for defaults for new Video/Image Cues.
Bugs Fixed
  • A change made in 11.10.6 could cause the default audio device to be omitted when creating a new production, if the Audio Driver Option 'Use BASS mixer' is set (which it is not by default).
  • This same error could display a message indicating the SoundMan-Server is required, when, in fact, it is not unless you use Live Inputs or LTC (Linear Timecode).
  • A change made in SCS 11.10.0 resulted in the DMX Master fader only being displayed in the Faders window if the external control setting was set to 'nanoKONTROL2 Preset B'.
  • If VST Plugins are specified but a plugin file is not present (eg because the cue file and device maps had been copied from another computer) then SCS did not enable you to search for the missing plugin.
  • In Video cues, sometimes 'Pause at end' would re-display the first frame, not pause on the last frame.
  • In Video cues, in some configurations the small monitor display may appear on a secondary screen, not on the main screen.
  • If a Video cue was playing when you opened a different cue file, the video would continue playing. SCS now issues 'stop all' internally when you click the Load button in the main window.
  • Corrected a bug in network connectivity that was causing an error message for sACN universe 2 to appear.
Locked
