How to change volume of audio MP3 in Edit
ozstar
Post by ozstar » Thu Jan 16, 2025 3:22 pm
I know this is a real 'doh' question but it still needs to be asked.
How can one quickly change the volume of a music track on the fly once it is discovered it is too different to the rest of the tracks.
oz
Nino
Re: How to change volume of audio MP3 in Edit
Post by Nino » Thu Jan 16, 2025 5:31 pm
You can drag the volume slider shown on the right hand side of the playing cue in the lower cue panel window to a more appriate level then click on 'Save Settings' in the main window toolbar and 'Save Setting <cue>' or 'Save Level/Pan for all above cues' (shortcut shift F10).
ozstar
Post by ozstar » Thu Jan 16, 2025 7:42 pm
Many thanks
PhilVale
Post by PhilVale » Thu Jan 16, 2025 9:45 pm
I use a BCF2000 and with the latest release that can be set to alter the volumes of the current running cue rather than the devices (set it to Pre-set C).
Normally though I would try and group my sound cues together and put them out to the same device. So for instance all my soundscaping for the storm. Then then I can quickly adjust the volume via the BCF if when it is playing I find volume is too loud and perhaps the actors can't get over it.
Hope that helps.
Phil.
