display of audio tracks
Micha2015
Post by Micha2015 » Fri Nov 22, 2024 6:39 pm
Hello,
in the tutorial videos from 5 years ago the audio tracks are shown in green and red.
In the current version both tracks have the same color. Can this be changed?
Is it possible to keep the zoom setting for the tracks when you change the cue window and then return? When you change, the zoom is always reset.
Micha
eightacre
Re: display of audio tracks
Post by eightacre » Sat Nov 23, 2024 7:55 pm
Yes. If you go into the "Options" menu, and then to "Display options/Colour scheme designer" you will find a button that says "Audio graph colours". I think that is what you are looking for.
Micha2015
Post by Micha2015 » Sat Nov 23, 2024 10:06 pm
Thank you very much,
I found the color setting.
The height of the window in which the waveform is displayed cannot be changed?
Nor can the zoom be changed to keep resetting.
Micha
eightacre
Post by eightacre » Mon Nov 25, 2024 1:35 am
The height of the cue panels is adjusted by going to Options/Display options/Cue panel height and altering the percentage.
