Intermittent GO! Delay
Posted: Tue Dec 12, 2023 8:21 am
by Chalky64
After creating a simple 5 cue project (all audio cues with manual start) I am sometimes experiencing a 1 second delay between pressing SPACE and playback of the file. This is very intermittent - most times playback is instantaneous - but every now and then the pause occurs.
I set registry idle times for the Realtek soundcard to 0 - but these were reset to 5 when I rebooted the laptop. I then set them to FF, which were retained after a reboot but sadly made no difference.
Setting 'Do NOT use WASAPI' and using the BASS mixer eliminates the intermittent 1 second pause, but all cues start a fraction of a second after pressing SPACE - so this is not a solution as the cues must start as soon as the operator hits SPACE as they are orchestral accompaniments for a piano concerto.
I am now extremely concerned that a pause may occur during the performance (this Sat 16th Dec). Is there any other setting (either within the program or in Windows 11) I could try?
Re: Intermittent GO! Delay
Posted: Tue Dec 12, 2023 8:50 am
by dee99
If you sent a log file from a run where this happens to support@showcuesytems.com they will take a look.
Logs can be found in "documents\scs logs folder".
Please try to open the program and replicate the problem, avoid opening the editor et if possible.
Best regards, Dee.
Posted: Tue Dec 12, 2023 7:24 pm
by Chalky64
Thanks Dee. I have sent logs in the past (albeit a long time ago!) so am aware of their location - but thought I'd ask here first in case I could save Mike the trouble of having to look into it.
The peculiar thing is that I have started SCS several times this morning and randomly selected cues in an attempt to trigger the issue - and every single time each cue started the moment I pressed SPACE. It's very strange as the problem was quite persistent yesterday (andn before), and I have not rebooted since it last occured...
Anyway - it goes without saying that there's no point sending anything for analysis until it does - but if and when it happens again I will forward the log as suggested.
