x32 Cue Control cannot be activated error
Posted: Thu Nov 30, 2023 5:38 am
by msinklair
When I load an existing cue file that was using cue control from the X32 I get an error.
CUE CONTROL
* Network In device 'server:port=192.7.29.92:10023' cannot be activated
To get it to work, I have to review the device map and make the cue control a dummy connection. I then have to send a command to the X32 from my cue file. Sometimes that will fail a few times. After it is successful, I can then un-dummy my network in and it connects and works fine. If I save the cue file with it dummy'd, then I can load without error. I still have to send a command, until it succeeds, before I un-dummy.
Any thoughts on this?
Re: x32 Cue Control cannot be activated error
Posted: Thu Nov 30, 2023 6:53 am
by dee99
Can you send a description of the problem and a log file from a run with the problem to support@showcuesystems.com
The log file can be found in your documents\scs logs folder.
If you send several logs please label them or let us know in the email detail for that run, thank you.
Posted: Fri Dec 01, 2023 6:11 am
by msinklair
Sure thing. I'll try to get to it tomorrow.
Posted: Thu Dec 14, 2023 2:15 am
by msinklair
I was able to finally send the email. I'm sorry it took longer than expected to get to it.
Posted: Mon Jan 01, 2024 9:33 am
by msinklair
Just wanted to follow up that my issue has been resolved thanks to the prompt support. Thank you very much!
