SCS 11.9.4 Available
Locked
Post by Mike Daniell » Mon Aug 15, 2022 11:08 am
SCS 11.9.4 is now available on the Download page of the Member Area.
New and Changed Features in SCS 11.9.4
  • MIDI Control Send devices now support 'Behringer X32 Digital Mixer' as a 'Remote Device'. Note that you will need an X-UF or X-USB expansion card installed in the X32 to use this feature.
  • For SCS Platinum users, the maximum number of Control Send devices supported in Production Properties has been increased from 16 to 64.
Bugs Fixed
  • When opening the recovery file, the message 'The cue file has been changed by another application' may be displayed.
  • Memo Cues loaded from a template file would lose their formatting.
  • When editing an MSC Control Send Cue, the 'Command Format' could not be changed.
  • If an Audio File Cue is linked to another Audio File Cue and the second of those cues is disabled, the link was not broken and playing the first cue would also play the disabled cue. SCS now checks cue and sub-cue 'Enabled' states when linking audio files.
  • Earlier SCS 11.9 releases did not allow an SFR cue to select a 'Go To' Cue as a cue to be stopped.
There is also an important change to the processing of certain timing actions, so we recommend you download and install this version even if none of the other changes are significant for you.
Locked
