[Resolved] Problems with audio cues loading
Posted: Fri Oct 04, 2019 1:17 pm
by kevint33
So I am using SCS for lighting and audio cues in a community theater. It usually works fine, and i am loving the latest update with the easier to program lighting interface. I have started having a random problem with audio cues however.
Occasionally in a show, one of the audio cues int eh show window will list the file as not loaded until time comes for the cue to be the next to execute. Then when it is time for it to execute it will be there to execute. Occasionally however when an audio cue comes up and it is listed as not loaded, it will then not execute. I will have to go into the editor, re-select it in the cue and then it will execute. I cannot seem to determine what the problems is. Anyone else had this problem? Happens with different files as well, not the same one and has happened on multiple shows since the last update.
Kevin
Re: Problems with audio cues loading
Posted: Fri Oct 04, 2019 2:09 pm
A log file will have been created and saved in a folder named "SCS Logs" under "Documents", and the name of the file includes a time-stamp indicating when the log started. Please email me the log file from a run in which this happened, and tell me which cue was affected.
Posted: Sat Oct 05, 2019 12:15 am
by kevint33
Will do, thanks Mike.
Posted: Fri Dec 06, 2019 2:25 pm
Problem solved. Caused by having the Production Property "Pre-Load ONLY the 'Next Manual Cue'" checked. Also recommended increasing the "Max. No. of Audio Files to Pre-Open".
