Video Cues jump to end (not playing)
Posted: Fri Feb 08, 2019 6:16 pm
We are using SCS 11.7 at our community theatre and have recently installed it onto a windows 10 machine. I have never had issues with video files in the past, but am now having an issue where every video cue, of any length, jumps straight to the end of the video and just flicks a quick image on the screen for a nano-second.
eg. I have a 30 second .mp4 file of flying through a starfield. When the cue is started the image of the start of the video flashes briefly to the second screen (a 7 x 4m HD LED screen) and then blacks out. Watching the cue progress in the SCS monitor it jumps from the start of the file to the end of the file as the cue is started ... that is it doesn't play. If check the "pause at the end of the file" option in video it will jump straight to the end of the file and pause the final frame on screen. I have also tried setting the in and out times of the video to start a few seconds in and this hasn't helped.
I can play these files in media player and VLC, so it's not codecs and is something in SCS.
I have installed the latest video codecs for 64bit W10, as well as the latest LAV files per the forums here (downloaded and installed this morning) but nothing seems to work. I have also tried .wvv and .avi versions of the video files, as well as other .mp4, .wmv and .avi files, and the same issue is happening.
Any suggestions on what the issue could be? Or where I should look?
Thanks in anticipation
Chris
Chris
