Animating/sliding image cues
Posted: Thu Aug 30, 2018 10:53 pm
I've had a search on the forum, but can only see a reference to a similar thing back in 2015, and just wondered if there are any updates/solutions?
For an upcoming production, I need to create a sequence that imitates the 'Tinder' app; ie, the images need to swipe left on the actor's command. I don't think I can easily do this a video sequence, as the timing would vary, and I need to react to the actor. Is it possible to have an image slide off to reveal the next in the sequence, rather than a straight 'jump cut' or fade to the next?
Our theatre group doesn't use the latest version of SCS (unfortunately I don't have it to hand to check version), so I wondered if it's maybe a feature of the current version?
I understand that SCS can run a PowerPoint presentation, so that is a possible workaround. The theatre we use has a Mac, so another option is to run the sequence on that with Keynote. Would be great if SCS could do it natively, however!
Craig
Craig
