Touch Screen Glich
domiii
Touch Screen Glich
Post by domiii » Fri Feb 26, 2016 1:07 pm
Having an interesting problem with SCS and a touch screen.
We just upgraded our sound system and sound computer at the theatre I work at. We have a Presonus Studiolive RM16 Mixer connected by Firewire to a new Acer i7 PC. I use Bass ASIO and Firestudio outputs. The computer has a 21" 10 point multi-touch monitor attached to it. We are running Windows 10 Pro and SCS v 11.4.2.1
The problem is with the touch screen. Everything runs great except for one thing, if you touch, hold your finger for a second and swipe it fires the next cue. This behavior happens anywhere in the main SCS screen, it does not happen in the editor window. You can still use the transport controls, select cues and press buttons as long as you don't slide your finger.
You can imagne how this effects changing volume on the fly!
Not sure if this is a bug or a Windows thing.
domiii
Re: Touch Screen Glich
Post by domiii » Fri Feb 26, 2016 1:20 pm
The show is over and I did some more experimenting.
It seems that it is a 'swiping' to the side thing. Dragging or swiping top to bottom scrolls is ok it is only swiping side to side.
Anyway to fix it?
Soundbloke
Post by Soundbloke » Sat Feb 27, 2016 4:58 am
A long touch on a touch screen on most devices is the equivalent of a right-click, so you must click the checkbox "Disable right click activating the 'Go' button" in Options/Shortcuts.
IMHO it should be disabled by default on any system!
domiii
Post by domiii » Sat Feb 27, 2016 8:55 am
I will try that tonight.
It is not so much the touch as when I swipe it actions the cue. If I just touch the screen and hold it doesn't fire.
