My problem is: I can connect the keytar to SCS *or* the lighting board, but not both. The research I have undertaken seems to suggest that I daisy-chain the devices together and get the middle device to pass on unwanted MIDI commands. Can SCS do this, ie if it receives a MIDI command it does not recognise, it resends it through the MIDI out port, the theory being that the MIDI command is intended for the lighting board, which would be the next device in the chain.
This is how I think I want to work things, but I'm open to suggestions if people can think of a more appropriate solution.
Many thanks,
Joseph
