Trigger cue via a relay /contact closure
I am fairly new to SCS and have done a quick search and found a few posts on this subject, I think the answer in no.....but is it possible to trigger specific cues in SCS via a contact closure which operates a relay board which connects to SCS via USB input? I hope I am making sense...typical use would be talent lifting a telephone handset to stop a 'phone ringing. I can see it could be done using a Midi convertor but I have all the relay boards etc already
Re: Trigger cue via a relay /contact closure
I'm use i-cubex system to trigger cue on SCS via midi control, I use i-cubex USB-microSystem for make SCS midi remote and Wi-microSystem (Wireless) for wireless sensor and trigger switch from actor to trigger cue on SCS, and other I'm try to test with arduino with midi shield to trigger on SCS It's work but for test only not sure for put in our show
I-cubex system
http://infusionsystems.com/catalog/index.php/cPath/21
some sample with arduino midi control
http://www.instructables.com/id/Arduino ... ontroller/
http://www.instructables.com/id/Arcade- ... ontroller/
Kai
I-cubex system
Kai
beverley.g wrote:I am fairly new to SCS and have done a quick search and found a few posts on this subject, I think the answer in no.....but is it possible to trigger specific cues in SCS via a contact closure which operates a relay board which connects to SCS via USB input? I hope I am making sense...typical use would be talent lifting a telephone handset to stop a 'phone ringing. I can see it could be done using a Midi convertor but I have all the relay boards etc already
KAI
AV Department
Phuket Thailand
