[In 11.3.0] MEMO cue on second display?
techniekhofplein
Post by techniekhofplein » Thu Feb 06, 2014 3:42 am
Hi all,
It might already be in there (11.2.5), but I haven't found it yet. Is it possible to play the MEMO cue on a 2nd display (as well)? I'd like to use this in a show to cue some actors. With a second monitor backstage we could 'announce' a cue without speaking/sound/intercom. Also we could cue the actors with this same technique with a monitor above the audience.
Ofcourse this can be achieved by an image cue as well but when the cue has to be changed (e.g. on a different text) then we have to render a new image with the updated cue. A memo cue would be perfect...
Thanks for any help.
Kind regards
Jaap Schledorn
Sound Designer
Hofplein Rotterdam
The Netherlands
Hofplein Rotterdam
Technical Department
Rotterdam, The Netherlands
Re: MEMO cue on second display?
Post by Mike Daniell » Tue Feb 11, 2014 9:56 am
There's currently only one display location for the memo cue, although you can drag that wherever you want. If there's more interest in having an optional duplicated display then this could be done.
enigmatheatre
Post by enigmatheatre » Sun Mar 02, 2014 7:28 am
+1 for this feature.
Post by Mike Daniell » Sun Mar 02, 2014 2:27 pm
Should the 'Memo cue on second display' be full-screen, with no title bar etc?
enigmatheatre
Post by enigmatheatre » Thu Mar 13, 2014 2:17 am
Mike Daniell wrote:Should the 'Memo cue on second display' be full-screen, with no title bar etc?
Yes that would be correct. It would be for using text output to a projector so no Titlebar.
Good news on the Video cross fade Mike. I will beta test of you need someone to.
Greig.
Post by Mike Daniell » Mon Apr 14, 2014 3:54 pm
The ability to display Memo cues on a secondary screen is now available in SCS 11.3.0 RC1. Let me know if there are any issues with this implementation.
enigmatheatre
Post by enigmatheatre » Fri Jun 06, 2014 6:34 am
HI Mike,
Thanks so much for adding the memo on a second screen it will come in very handy.
One more thing if it is possible to make it fade in and out then that would be great :D
I have shown SCS to lots of amature theatre groups most of them have now purchased a copy knowing how good the software and support is.
Thanks again for your hard work.
Greig.
Post by Mike Daniell » Fri Jun 06, 2014 4:11 pm
enigmatheatre wrote:One more thing if it is possible to make it fade in and out then that would be great :D
I have been considering this, but the mod I will have to make is fairly complicated and you could manually do something similar to the proposed mod!
To provide fades of a displayed memo requires SCS to capture the memo display and create an image file of the captured display. The image can then be faded in and out just as with a video/image cue. So until that feature is added to SCS what you could do is take a screenshot of the memo displayed on your secondary screen, save it as an image file, and then use a video/image cue instead of a memo cue.
enigmatheatre
Post by enigmatheatre » Sat Jun 07, 2014 4:03 am
HI Mike,
This is kind of what I have to do at the moment but I make it up in powerpoint then export the slide as a jpeg then import it in to SCS. I find a very long way of doing things so if there was a way to "Automate" the process then I would be very greatfull.
Thanks again.
Greig.
