Problems in SCS9 (fix in 9.1.2)
After key in the registration detail, it will be authorize the that particular time, and after restart of the program, it will goes to the demo mode again.
The speaker selection is only available for x2 L+R... The other option are dim.
Will this be the problem of my registration code.
Thx
KMK
Thx
KMK
Is this under Chinese Windows or some other multi-byte character set? Sounds like an issue I had in SCS 8 but which was fixed after I made some modifications to the encryption algorithm.
The speaker selection issue is probably related. What you are seeing is the SCS-Standard device option (2 devices), but since your registration is for SCS-Professional you should be seeing all the device options.
Similar problem?
It seems that I may be having a similar issue. I'm running version 9.1.1 with the Professional level license registration.
When I go into the "Editor" and select "Production Properties", I'm unable to (or can't figure out how to) add more devices in the in the "Sound Devices Required for this Production" table. I have the default "FOH" isntance of "Device Name Used in Cues". All the other device lines in the table are grayed-out.
I know that all the audio devices installed in the computer are recognized, because they appear in the "Physical Device" pull down menu as options for the default "FOH" device, two standard computer sound cards (Yamaha and Sound Blaster) and one M-Audio Delta 44.
The on-line help indicates that I should be able to create new entries in this table. I cannot. I have this problem on both my "home PC" for editing and the "theatre PC" for playback.
Any ideas about what I'm doing wrong?
BTW, the OS is Windows XP, SP2 with all the latest MS mandatory updates applied.
Thanks, in advance.
Dave Nelson
Thanks, in advance.
Dave Nelson
Dave,
You mention you are using 9.1.1. Try the latest version, which you can download from here. You should find this will enable you to select devices in all the 'Sound Device' lines in the Production Properties. If you still have a problem using 9.1.3, let me know.
Mike
Mike
