[In 11.7.1] setting up a backup laptop --> master/slave
Re: setting up a backup laptop --> master/slave
Topic now split for master/slave requirement
Yes sure! I use it that way.Mike Daniell wrote:Noted, especially the comments that a 'slave' should not send network, MIDI, etc. IE, only 'stand-alone' or a 'master' mode should actually send anything from a control send cue or a lighting cue. Can anyone think of a scenario where a 'slave' should be able to send output from a control send or lighting cue?StasUshomirsky wrote:Please consider several of my posts above, regarding the desired behavior of the Master/Slave setup.
1. Laptop Master - ShowCueSystem and Light by M-PC controlled via MSC
2. Laptop Slave - ShowCueSystem and Light by M-PC controlled via MSC
Please let it be flexible. No need to cut off control send functionality at the slave by default. Let the user choose.
Tocsin
Thanks, Tocsin. Is your slave SCS effectively controlling a slave lighting controller or similar, meaning that both master and slave SCS instances need to send MPC?
Yes they both need to send MSC independendly. The Slave Laptop is doing the exact same as the master. SCS is doing sound/video and triggers the light via MSC and control send through loopMIDI at M-PC.Mike Daniell wrote:Thanks, Tocsin. Is your slave SCS effectively controlling a slave lighting controller or similar, meaning that both master and slave SCS instances need to send MPC?
If the Master failes, i switch the sound on the audio console, the video with a KVM and the DMX is merged with Slave Laptop and a Lighting desk.
Tocsin
As we approach our biggest show of the year here at the Starbright Theater, I just wanted to check in regarding the master/slave functionality. Any news Mike? Thank you!
Stas Ushomirsky
Starbright Theater
Campbell, California
Starbright Theater
When is your 'biggest show of the year'?
May 24-25
Stas Ushomirsky
Starbright Theater
Starbright Theater
We've started work on the design for this, but have a terminology issue. There seems to be a certain amount of discomfort around the world regarding using the term 'master/slave' for computer connections. One alternative suggestion is 'primary/secondary', but to me it seems that 'master/slave' best describes the control flow. Any opinions or suggestions?
Concern seem to have been floating around for some time. Drupal has suggested Primary/Replica. As Master seems widely accepted as in Master Document, perhaps Master/Replica would be a compromise?
My two SCS computers in the booth are actually called:
Primary / Backup
Can we go with that?
Primary / Backup
Stas Ushomirsky
Starbright Theater
Starbright Theater
Thanks for the suggestions, Malcolm and Stas. I've decided to use the terms 'Primary' and 'Backup', or more specifically 'SCS Primary' and 'SCS Backup'.
I'm late but I like the proposal of StasUshomirsky. Primary/Backup.
