Network connction with SCS 11.5.2.4
dwbc
Post by dwbc » Mon Jan 09, 2017 11:01 am
I have just installed the latest upgrade and want to connect SCS from my laptop to an X32 mixing desk. However, I cannot seem to get SCS to recognise any network connection. The only Control Send Option appearing in Devices is MIDI. I have obviously not set up something correctly to start with. I am sure the LAN connection between the Laptop and the X32 is OK because I am running the X32 Edit software OK using a LAN connection. I am not using a router, just a single cable between the two with the IP address in the X32 set up manually.
Can anyone help please?
Thanks, David
Re: Network connction with SCS 11.5.2.4
Post by Mike Daniell » Mon Jan 09, 2017 1:48 pm
David,
For network access (both cue control and control send) you will need to upgrade to SCS Professional Plus. See Compare Levels.
dwbc
Post by dwbc » Wed Jan 11, 2017 11:35 am
Thank you for the advice. I have now upgraded to Professional Plus and am happily sending Mute & Unmute commands from SCS to the X32. The drop down menu on the Control Cue page gives me easy selection of the 32 input channels - excellent. However can you advise me if it is possible to send the same commands to the FX Channels (channels 9 - 16 on the third layer)?
David
Post by Mike Daniell » Wed Jan 11, 2017 5:41 pm
David,
I haven't been able to check this yet as my X32 is off-site, but you should be able to use the OSC Free Format command type. For a detailed list of OSC commands for the X32 I recommend the Unoffical X32/M32 OSC Remote Protocol by Patrick-Gilles Maillot, available from https://sites.google.com/site/patrickmaillot/x32. btw, the link to this document in the SCS Help is incorrect - I'll fix that in the next version of the Help.
To mute an FX return the command would be "/fxrtn/[01…08]/mix/on ,i 0" (without quotes) eg "/fxrtn/03/mix/on ,i 0" to mute FX return 3. To unmute, replace the final 0 by 1, eg "/fxrtn/03/mix/on ,i 1" to unmute FX return 3.
If I've got that wrong, let me know and I'll go and test this with my X32.
dwbc
Post by dwbc » Wed Jan 11, 2017 8:44 pm
That works a treat - thanks so much. :D
David
sjwicks
Post by sjwicks » Thu Jan 12, 2017 8:13 am
Thanks for the info Mike. Earlier, Dave and I struggled to work out the syntax .
Simon
