SCS plans for 2010
SCS plans for 2010
Post by Mike Daniell » Wed Dec 30, 2009 11:24 am
For sometime now I have been working on porting SCS to a new development environment. This project is progressing well and the new version will be released in 2010. This will be named SCS 11. Here is a summary of the new and changed features that will be in SCS 11:
  • The new development platform provides or makes possible a number of benefits, including:
    • A more efficient processing engine, which means less processing overhead and better control of internal operations.
    • All language-specific text can be loaded from optional language files (or similar), making it feasible to provide German, French, Spanish, etc user interfaces – even both US and British English! The built-in language will continue to be US English.
    • SCS 11 will be compiled in Unicode mode, providing support for multi-byte character sets such as Chinese and Japanese.
    • The initial version of SCS 11 will be 32-bit (as is SCS 10) but shortly afterwards a 64-bit version is expected to be available.
  • In the SCS 11 User Interface, ‘Display Options’ and ‘General Options’ will be combined into a single ‘Options’ button on the toolbar. The display options will be on a new tab in the existing ‘general options’ window, and the color scheme designer may be on another new tab (haven’t finally decided on that yet).
  • There will be additional layout options, including the ability to nominate where the ‘Next Manual Cue’ information bar will be displayed, so you will be able to locate that at the bottom of the screen if required (see this forum posting).
  • The cue list on the main window will no longer highlight the next manual cue using the Windows default ‘selected item’ color. This highlighting has caused concern as glancing at the screen while a cue is running doesn’t highlight the running cue but the next manual cue. A new row marker column will be displayed on the left, which will identify by distinct colors running cues, stopping cues, and the next manual cue.
  • In the Options window, the ‘Mixer Levels’ tab will be removed. Since the introduction of Vista this tab has become fairly meaningless and doesn’t cover the complete range of ‘mixer’ faders.
  • In the Options window, the ‘Editor’ tab will be removed. It currently only contains one field (graph auto-display max file length). If there is demand for this option to be reinstated then I will consider providing access to it directly from the Editor, not from the Options.
  • In the Options window, I’m considering moving the various device ‘options’ to a new location as they are not really ‘options’. I’d welcome your thoughts on that.
  • The toolbar in the Editor will be redesigned as follows:
    • The cut, copy, paste and delete buttons will be moved to the vertical sidebar below the cue movement buttons, so they will no longer be required in the horizontal toolbar.
    • The contents of the four tabs (File, Production, Cues and Sub-Cues) will be combined into a single toolbar, so the tabs themselves will be removed.
    • The existing separate buttons for adding different types of cue will be replaced by a single ‘Add Cue’ button containing a drop-down list of cue types. Similarly for Sub-Cues. On advantage of the drop-down list is that new cue types can be added without having to find real estate in the toolbar for buttons for the new cue types.
    • The existing ‘Production’ buttons will also be displayed in a drop-down list under a single ‘Production’ button.
    • A new ‘Favorites’ group will be included in the toolbar. For functions you frequently use, such as ‘Add Audio File Cue’, you can include these in your ‘Favorites’ so you can continue to have single-click access to these functions instead of having to select from a drop-down list. By default the Favorites group will be populated with ‘Add Audio File Cue’ and ‘Add SFR Cue’, but you will be able to setup your own Favorites.
  • In the sub-cue properties, the ‘Description’ field will be hidden unless the cue has two or more sub-cues. If a cue has only one sub-cue then that sub-cue will internally inherit the ‘Description’ of the cue. The existing method of auto-populating the Description will be retained (such as using the title from an MP3 file), but the auto-populating will be tightened up (or possibly disabled) if you move cues around (see this forum posting).
  • The Cue Properties panel may be adjusted to optionally hide the ‘Standby Control’, thus making more space available for the sub-cue properties panels.
  • I may add a new cue property for ‘Script Page No.’ or similar, as per this forum request. The title of this field you would be able to set yourself, so you could replace this with ‘Page/Line’ or whatever you like.
  • Additional options will be added to the ‘Sub-Cue Relative Start Time’. Currently this field is the sub-cue's required start time relative to the start of the cue, but there will be a facility to select other options, such as time relative to the start or end of the previous sub-cue within this cue. Also, an alternative timing method will be provided as an option, where the timing is derived from the playback position of the first sub-cue – see this forum posting for details.
  • New (sub-)cue type properties will be available for the ‘Go To Cue’ and ‘Set Position’ cue types, replacing the existing implementation that uses special formatting in the ‘Note’ cue type.
  • Level Change cue properties will include a new checkbox ‘Stop when fade-out completes’, as per this forum request.
  • Additional fields will be included in Bulk Edit (‘Cue Enabled’ and ‘Audio Devices’) as per this forum posting.
  • A hotkey for global fade and pause / resume will be implemented as per this forum posting.
In line with our current pricing policy, SCS 11 will be available free to all users who have a current update plan, which includes all users who purchased or upgraded their SCS license within 12 months prior to the release of SCS 11. Registered users without a current update plan will be able to download SCS 11 after purchasing an update plan.
Nearer to the time of the release of SCS 11 I will be looking for beta testers - let me know if you're interested. You will need to have a current update plan to participate in beta testing.
runawaymartin
Re: SCS plans for 2010
Post by runawaymartin » Sat Jan 02, 2010 3:12 pm
Hi Mike . . . the new development platform and your plans for SCS 11 sound great (no pun intended). Unlike many town planners, you have seen the need to stop unchecked urban sprawl and consolidate new development into a more efficient and pleasing environment.
I think all of your ideas are spot on and I’d be more than pleased to be a beta tester at the appropriate time.
The idea of combining ‘Display Options’ and ‘General Options’ within a more comprehensive ‘Options’ button is good but I wondered if it would be practical to call it say ‘Options & Settings’? Further menus within that drop down menu could include ‘Permanent Settings’ and ‘Production Settings’. ‘Permanent Settings’ would include the device tabs now under ‘General Options/Permanent Options’, while ‘Production Settings’ would include the device tabs currently under ‘Editor/Production Properties’.
Maybe I'm missing the point but I’m not sure what the concerns are regarding color highlighting when a cue is running. The SCS default color makes sense to me as it coordinates with the VU display and stands out well. I’ve actually changed my Windows default ‘selected item’ color to silver so it doesn’t stand out so much.
Rather than having another column on the main window would it be preferable to have an additional color setting for ‘Next Manual Cue’? btw . . could the color file automatically accompany the main SCS file when being transferred from one computer to another?
Cheers and a Happy 2010 to all . . .
. . . Martin
Martin Norris
Sound Achievements P/L
Runaway Bay, Qld, Australia
Post by Boswell » Sat Jan 02, 2010 7:49 pm
"Rather than having another column on the main window would it be preferable to have an additional color setting for ‘Next Manual Cue’? btw . . could the color file automatically accompany the main SCS file when being transferred from one computer to another?"
Now that's a good idea, spot on Martin, fully agree
Post by Mike Daniell » Sat Jan 02, 2010 8:20 pm
OK, I can drop the idea of a new marker column and provide a facility for you to select your own color for the 'next manual cue'. I could make this new marker column an option if anyone's interested in having it. If so, please let me know, because otherwise I will drop it out.
ColinBurgess
Post by ColinBurgess » Sat Jan 02, 2010 10:31 pm
I feel that having an extra column showing what is happening and what is coming next is a good ides, it should only need to be about two thirds the width of the Cue column so it shouldn't take up to much screen width. As a lighting tech who is asked to help with the sound on occasions I feel it would be usefull. In the ideal world lighting techs only deal with lights and sound technicians look after the accoustics, in the real world often the production company cannot aford to employ both techies or cannot find both for their production so therefore the poor ligting guy is told you'r a techie you can you operate the sound! On my lighting programe it has a simple column with a button with shows what is fading in, what is fading out and what cue is active i.e. what is ligting the stage, the next cue does not have to be shown because that is always the next cue below the lit buttons. So therefor a simple button with colous to show what is fading in, what is fading out, what is running and what is the next cue could be very usefull. Also if its a button could hitting the button start that cue and take the list to that point, could be very usefull in rehearsals for jumping to a cue! Also in the ideal world the Sound designer sorts out his sounds and his cues, programmes the show and runs the cues; in the real world the director gathers the sounds together on various CDs, MDs, computer memory sticks etc takes them to the theatre gives them to the theatre technician to load onto the computer and into SCS and the lighting guy just brought in for that show is asked to operate! I feel that it could be a very good idea but if the dedicated Sound designers find it takes up to much screen area could it be able to be removed for them! Just some random thoughts I hope it helps the discussion!
Post by Mike Daniell » Sun Jan 03, 2010 8:11 am
Thanks for your comments, Colin. That's all very useful. I'll retain the marker column but make it optional. Also, as with other columns you will be able to adjust the width to suit your requirements, and SCS will remember the column width the next time you start the program.
ColinBurgess wrote:Also if its a button could hitting the button start that cue and take the list to that point, could be very usefull in rehearsals for jumping to a cue!
SCS does currently reposition the cue list if you click on a cue in the list. I'm not sure about getting SCS to start the cue on clicking this 'button' - I'd rather leave that operation separate so the cue isn't started unintentionally. The new marker would not actually look like a button - just a filled-in cell in the cue list.
rino.col
Post by rino.col » Tue Jan 05, 2010 2:24 am
Hi Mike... no chance to have video fade out in the SCS 11?
Post by Mike Daniell » Tue Jan 05, 2010 5:49 pm
rino.col wrote:Hi Mike... no chance to have video fade out in the SCS 11?
I'm still waiting on a reliable video dll that contains the necessary functionality. We may have to build our own or contract someone to build it for us.
dee99
Post by dee99 » Wed Jan 06, 2010 7:52 am
HI, count me in for beta testing as usual please Mike.
jkowtko
Post by jkowtko » Thu Jan 14, 2010 5:02 am
ColinBurgess wrote:I feel that having an extra column showing what is happening and what is coming next is a good idea
Isn't this the STATUS column? Granted the Status column doesn't show a whole lot of value choices right now, you can can easily add more values to indicate different states.
John Kowtko
Sound Designer/Engineer
Redwood City, CA USA
Post by Mike Daniell » Thu Jan 14, 2010 10:47 am
Yes, John, it is like the status column, except that the marker column has no text and so can be much narrower. Actually got the idea from my years of working with Oracle Forms!
What other status values would you like to see?
jkowtko
Post by jkowtko » Fri Jan 15, 2010 2:26 pm
Hi Mike, I just fired up SCS to check on this issue.
Looking a the top "Cue List":
* Definitely the problem in my mind is that there is no separate color for the "next manual cue", to make it stand out. (This is in the top panel cue list.)
* The Status column already tells you when a cue is fading out, completed, playing, ready, or not loaded ... I would add another status value "next cue" or just "NEXT".
* You might also consider allowing the next manual cue color to be a blinking color (pick two colors and it blinks back and forth between them.
Looking at the "Cue Panel":
* It seems like the status box in for the cues in this panel should always match the color of the associated cue in the Cue List above. There is one occurrence I noticed where the color schemes go out of sync -- when a cue fades out, the status box in the Cue Panel turns bright red, but the associated cue in the Cue List does not change color. I realize you allow us to set color by type of cue, and also by cue status ... I guess there are a couple areas in there where there it could get a bit confusing if both panels don't reflect the same color at any point in time.
* You might consider adding an Option to allow the user to specify that only running cues are displayed in the Cue Panel.
Thanks. John
John Kowtko
Post by Mike Daniell » Sat Jan 16, 2010 11:26 am
Thanks, John. Useful info and suggestions there.
jkowtko
Post by jkowtko » Sun Jan 17, 2010 5:05 am
Sorry, I didn't completely finish my thought, Mike. Based on my responses above, I don't think having another column for "Marker" is needed. I think the changes to the status column and the coloring enhancements would take care of the need.
Thanks. John
John Kowtko
terrein
Post by terrein » Wed Feb 03, 2010 7:37 pm
i would love keyboard shortcuts in the editor for adding new cues, eg. Ctrl+A for new audio cue, Ctrl+F for new fade cue, etc
