possible bug in 9.5.2? (fix in 9.5.3)
rob_keeling
Post by rob_keeling » Sat Mar 22, 2008 3:44 am
It seems that when using midi sub cues the second (and subsequent times) you go into editor and look at a midi cue you get the dreaded sub script out of range error, and (i think) the note value is not displayed)
Is this happening for others?
Edits are correctly saved, just the error on display.
RobK
Re: possible bug in 9.5.2?
Post by Boswell » Sat Mar 22, 2008 7:06 am
This does not happen to me, I've got upto 24 Midi subcues under the 1 main cue and also mixed midi, audio & stop/fade sub cues, no problems with any of them under 9.5.2
rob_keeling
Post by rob_keeling » Sun Mar 23, 2008 2:22 am
Interesting, I am running under XP if that is likely to make a difference.
May be just one of those things, will try the scs file on a different PC and see what happens.
RobK
Post by Boswell » Sun Mar 23, 2008 2:52 am
Sorry, I should have said I'm running XP pro SP2
Post by Mike Daniell » Sun Mar 23, 2008 8:02 am
rob_keeling wrote:It seems that when using midi sub cues the second (and subsequent times) you go into editor and look at a midi cue you get the dreaded sub script out of range error, and (i think) the note value is not displayed)
Rob, I've emailed you directly regarding this.
