New and Changed Features in SCS 11.9.8
- The Bulk Edit screen now shows the Activation method (eg Manual, 1.00 ae Prev, etc) for all field types to be changed, except for 'Audio Levels' which continues to show Device in that column.
- The SoundMan-Server option to force audio processing onto a single processor has been removed.
- Bulk Edit was not properly handling clearing (setting to 0) Fade In and Fade Out Times.
- If an MTC sub-cue is linked to an Audio File cue or sub-cue, then on 'Stop All' the Audio File would continue playing, albeit silently. On activating something like starting the Editor, the Audio File playback would then be heard. The Stop All processing should not have resumed playback.
- The SoundMan-Server processing in SCS did not handle multiple ASIO interfaces correctly, especially regarding determining the sample rate to be passed to SoundMan-Server.
