Windows 11
Re: Windows 11
Post by Mike Daniell » Thu Nov 11, 2021 6:40 pm
File received. The file "wind.1.wav" contains 100 'cue points', all at position 0, as confirmed by GoldWave. The file "wind.2.wav" also seems to contain 100 cue points, all at position 0. The file "wind.2.1.wav" seems OK - no cue points.
I suggest you convert "wind.1.wav" and "wind.2.wav" to mp3 format, which doesn't support cue points. Then change the cues that use those wav files.
Let me know if that helps the Windows 11 performance issue. If it doesn't, then please email me another log file.
PeterMount
Re: Windows 11
Post by PeterMount » Thu Nov 11, 2021 7:16 pm
Thanks Mike.
I'll make amendments and see...
PeterMount
Re: Windows 11
Post by PeterMount » Tue Nov 16, 2021 10:21 pm
Mike
Apologies for delay...
I'll be back to you soon when I've done a full test.
I'm using windows10 computer now for this current show which works fine.
Peter
Mark Gerard Albers
Re: Windows 11
Post by Mark Gerard Albers » Fri Jun 03, 2022 3:19 am
Hi all, I've been reading the thread, has there been any resolve for SCS on windows 11? Unfortunately my machine is falling apart and I'm basically forced into windows 11 ( Windows 10 doesn't play nice with 12 gen Intel chips )
Thank you!
Mark
Re: Windows 11
Post by Mike Daniell » Fri Jun 03, 2022 8:10 am
I'm planning to install Windows 11 on my production laptop in August, following the end of a production I'm currently working on. I will then be able to run extensive testing of SCS under this latest version of Windows.
PhilVale
Re: Windows 11
Post by PhilVale » Tue Jun 07, 2022 8:25 pm
Just to report that I ran a relatively small cue file (about 6 tracks and 4 playlists) without any problems this weekend on Windows 11.
Not by anymeans a conclusive test but it built a little confidence that we were ok at least at an audio level. Next might be to attach my BCF2000
Mark Gerard Albers
Re: Windows 11
Post by Mark Gerard Albers » Wed Jun 08, 2022 9:10 pm
Thanks guys! Definitely makes me feel a little better.
Mike, I'll be sure to keep log files if I run into any problems.
Re: Windows 11
Post by Mike Daniell » Thu Jul 28, 2022 6:22 pm
See forum topic SCS and Windows 11.
